Neal_B_
Feb 07, 2017Explorer II
How much pin weight?
I have a 2002 Silverado 2500HD, duramax, allison. Is 1615lbs. to much pin weight for this truck? I am considering a new 5th wheel and was concerned about this.
GM gives their 2500 trucks a 6200 RAWR.
The '02 2500 can weigh in the 2800 lb range which leaves you with around 3200 lbs for a payload
RAWR can be the lessor of tires/wheels/rear spring pack. Never exceed a drive or steer axle/tire load ratings and you will fine.
