RoyC's avatar
RoyC
how much weight can i tow?
I have the setup in my signature. The camper unloaded is 3500 pounds. I believe my truck towing capacity is 12K. It moves my camper with ease. So, with the unloaded camper on the truck, roughly how much can I tow - as in a travel trailer on the way to a winter home base 1500 miles away - some mountains no rush.
edit: I don't want to strain the truck - she's my other baby.
edit2: I don't run the 16.5" rims anymore but some of the strongest 16" wheels and tires.
  • I would think the limiting factor will be rear axle tire capacity. The only sure way to find out how much they are loaded is a trip to the scales. With some measurements of wheel base of truck and distance from rear axle centerline to hitch ball you can then calculate the amount of tongue weight the tires will be able to handle.
  • I tow 2 different single axle trailers at about 2500# each with my 04 2500HD 6.0 gasser with no problems.
    What I would suggest is to install a new receiver like a Curt 2.5" and an ext. bar reduced down to accept a standard 2" mount. "E-trailer" sells them.
    The OEM 04 factory hitch is weak . Being that an extension is needed on the truck camper, i opted for the 2.5" to offer a little more beef .
    I guess you'll be ok between what I tow and this guy who carries spare campers in case one leaks. :B
