Campfire_Time
Apr 01, 2015Explorer
APT wrote:
2008 is 4-spd trans. Axle ratio is important as 3.08 performance and ratings is significantly different than 3.73 and 4.10. If you do not know, look in the glove blox for the RPO sticker. You will have one of these in your list:
GU4 : AXLE REAR, 3.08 RATIO
GU5 : AXLE REAR, 3.23 RATIO
GU6 : AXLE REAR, 3.42 RATIO
GT4 : AXLE REAR, 3.73 RATIO
GT5 : AXLE REAR, 4.10 RATIO
You should also verify you have Z82 in your list for the HD trailering package. That includes transmission cooler which is essential for any high walled trailer.
Assuming you have 3.42+, towing any high walled RV means 3rd gear, 2400-27000rpm on flat ground at 65mph. That's a lot like my prior truck. Downshifts to 2nd on hills at 4000-5000rpm. As Terryallan said, the truck will do that all day long (keep an eye on trans temp). The driver may not be pleased with that level of performance.
Stick to under 6000 pounds dry for a TT. That's 7000-7500 pounds loaded.
If you have 3.08 gear, just get a replacement truck. :)
You're a knowledgeable guy and I enjoy your posts, so it's not that I disagree with anything you said, but did you even read the previous posts? I already posted everything about the gears. To be a bit more precise, 3.08 gears were not available on any of the 1/2 ton PUs in in '08. I listed only what was available with the 5.3 (this is why I always insist that folks check their owner's manual and not rely on Internet towing guides). There was a 3.23 but that was only available with the V6 or 4.8l V8 so it doesn't apply to him.
Hopefully he has the 3.73s.
44,059 PostsLatest Activity: Mar 18, 2026
