BradW
Jun 15, 2013Explorer II
Jlschuma wrote:
How much over gvwr is too much?
- if the 2,500 lbs is based on the manufacturer's claimed weight, it will end up more like 3,500 lbs with accesories, liquids, gear, etc
- whatever you tow on a 24" extended hitch will add twice the tongue weight to the rear axle
- practically every swr truck you see hauling a hardside truck camper is over the gvwr between 500 and 2,000 lbs
- how much over gvwr is still safe depends on a lot of things like, how fast you drive, your driving skills in a heavily loaded top heavy high profile vehicle, how well you maintain your truck (and tires in particular), what you are towing while hauling the camper, etc
Brad
