- kayzapExplorerEvery four years.
Have an aluminum trailer and the cost to repair skin damage from a blown tire is a lot more than a set of tires. - ZINGERLITEExploreron the side of the freeway in a angry panic! When they need to be replaced obviously!
- StirCrazyModeratormy last trailer I went 10 years with out a problem, the one before that 10 years no issues, this one i am on 4 years and I noticed a broken bead on a tire so I replaced that this spring. kinda when they need replacing for me, but I am wondering if the type of roads are different causing more stress on the tires down there? who knows.
Steve - 5-6 years.
Last year I bought a used cargo trailer which had really old tires on it. I replaced them with Goodyear Endurance
I also have the tires / wheels balanced for the reasons described in this video. - Grit_dogNavigator III
falconbrother wrote:
How often do you replace your trailer tires?
ROFLMAO..... never saw this question asked before.....
Did a new rvnet member steal your handle or are you just pulling our leg here??
But at least it was a very vague, ambiguous question sure to stir up a bunch of useless fodder and you can pick the “right” answer to support your own opinion! - spoon059Explorer III start getting nervous around the 5 year mark. I've never had a tire failure, but I always replaced with a heavier duty tire than necessary. Currently running Goodyear Endurance E rated on a 9500lbs GVWR trailer, rated at around 2800lbs per tire.
- JIMNLINExplorer IIIAverages around every 7 years and 50k-55k miles with 16" LT E. Same with other bumper pull/GN non rv trailers with 15"/16" tires. Non of my trailer sit in the sun when not being used.
- mosseaterExplorer IIDate codes seem to run 7 years or less. Inspection generally shows cracks and tread separation well before the tread is gone. On my third set in 13 years. The originals were total junk. Been running Maxxis since.
- LwiddisExplorer IIEvery four years. I’m conservative and want no problems. LR D for my light TT.
- TravelinDogExplorer IIIt seems that if I get 4 years out of trailer tire I'm doing good.
Even with very low miles they just don't last. I've been lucky in that since 2004 I've only had 3 blowouts on the highway and suffered no damage to the trailer.
I usually spot a bad tire when inspecting them before a trip. Usually it's sidewall or tread bulge but a couple of times the tread just separated from the carcass.
I did go to D rated tires but they don't seem to last either.
44,056 PostsLatest Activity: Nov 19, 2013
