- Winged_OneExplorer
MTPockets1 wrote:
Diesel or Gas? .... My 6.7 Diesel says 10w40 synthetic for towing and change annually unless engine monitor advises sooner. My monitor has never advised as I change oil about 6000 miles, 30 - 40% tow miles. Gas engines more often due to less oil capacity.
That's 5w-40, for clarification.
And I change in the fall before being put away for the winter, but only 6,600 miles last year, even less this year. - dodge_guyExplorer III would say with little use to change it once a year. The truck will always have sime type of load so the engine will always burn off any condensation that may start. If you use synthetic i would go a max of 6k miles.
- MTPockets1ExplorerDiesel or Gas? .... My 6.7 Diesel says 10w40 synthetic for towing and change annually unless engine monitor advises sooner. My monitor has never advised as I change oil about 6000 miles, 30 - 40% tow miles. Gas engines more often due to less oil capacity.
- GeoBoyExplorerMy 05 has 37,000 miles and I change it once a year, just before I put it away for the winter. I use Amsoil in the engine, transmission and differentials. Truck is used mainly for towing our TT and only in the spring, summer and fall.
- ib516Explorer II
2oldman wrote:
I'm still working on 'if little us'
Add an "e" on the end - it makes more sense then. - dennisgt60ExplorerI have changed oil twice. Truck will be two years old in July. Has 5,900 miles on it, all non-towing.
- 4x4ordExplorer IIII use synthetic in my Ford and change the oil every 25,000 km. Engines in our heavy equipment use regular oil and the oil is changed every 600 hours. The equipment manufacturers recommend every 600 hours or 1 year and don't specify synthetic.
- 2oldmanExplorer III'm still working on 'if little us'
- Golden_HVACExplorerIf you are using a quality synthetic oil, then you can go a year without changes.
Fred. - wilber1ExplorerIf it's on warranty, whatever the manufacturer says.
44,056 PostsLatest Activity: Dec 27, 2025
