2oldman wrote:
skipro3 wrote:
.. they are floating at 13.8 when finished. Close enough for government work! Ha!
Floating on solar? How do you connect your coach batteries to the big alternator to take advantage of it?
Through the Blue Sea battery isolator/automatic charging relay that Lance has on the camper.
The beauty of DC is that you can parallel in several charging sources without too much bother. Unlike AC where the phase must be synch'd first, before cutting into a 'grid'.
So, in my case, I have my solar and my Lance AC battery chargers in parallel to my Lance batteries and to my Blue Sea. Then my truck batteries, with the trucks alternator, on the other side of the Blue Sea.
Now, when the Blue Sea senses that the camper batteries are 12.8v or less, it isolates the truck from the camper. When either truck or camper is above 12.8, then the Blue Sea connects them back again. Great because the solar will charge the camper batteries first, then once those are up to 12.8volts, will begin charging the truck in parallel as well. If the truck batteries are already 12.8 or higher, no problem because they don't represent a load to the charger(s).
It works, I've tested it every which way and my truck and camper batteries are isolated when needed to keep the one from draining the other's batteries and combined when a source, any source allows one or the other to charge above 12.8vdc.
BTW I use a Morningstar solar charger.
