I had two TCs. A pop up and a hard side fiberglass.
I used both for work. I would use them weeks at a time, be home a week or two then head back out.
It is a big enough pain that when home only one week I would leave it on. Two weeks and then just depends on how much driving I planned to do between (usually I was tired of driving so avoided it when home).
It is simple in theory, but does take time. It can be a chore. Tailgate needs to come off and go somewhere safe, don't drop it, its heavy but easily manageable. The camper is always sitting on something (X's, saw horses, pallets) so raise camper, remove platform, store platform/move platform. Prep truck, which for me involved the batteries that stayed in the truck bed, the electrical connection, putting boards in the bed, the rubber mat all just so. Back truck in most of the way, connect the things, back in the rest of the way. Some ppl are good enough they get it perfect the first time, prepare to do a few back-n-forths to get TC centered where u want it. Lower TC. I had remote motors but it still was a chore. I had air bags, so air up the air bags to get truck level again. Lug out the Troqlift tie-down arms, the chains and hook it all up, tighten down the tie-downs. Fill water if you prefer to drain out water for storage to make TC lighter and not stress the floor (depends on quality of your TC). Dont forget that license plate move. Hook up trailer wires to TC, check, Two mirrors out.. Good to go.
Yea, it is a bit of work.
I got rid of TC.
Now I have trailer: Back truck up, drop it on the ball, clip the chains in and the 7-pin. Done.
Be sure this is what you want.
The Pop-up is neat, but unless it is an Alaskan you are in a tent when the top is up, all the noises and lack of insulation as a tent. Lack of security of a hard wall (not that campers are hard to break into).
The hard side is nice too, heavy, and lot of weight on your expensive truck with expensive front end parts - as opposed to super cheap easy-to-fix trailer axle and leaf springs. Your truck is going to carry the burden and weight and get worn out faster....
Keep all this in mind...
