Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or block...
After unhooking I run front legs up/down to level then lower them roughly 1" of travel. Run rear stabilizers down until snug....I use 6X6 block under pads so that stabilizers have wider stance. I then run front legs back up to level
