Dtaylor
Sep 12, 2013Explorer
How tight?
Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or block...
elivi8 wrote:I'm with you on this Ryan. Never use your stab. jacks to level. Level the trailer side to side first with blocks under your tires then for and aft with your tounge jack. Then and only then bring your stab jacks down to stabilize.
I put each one down until it just touches the ground. Then I walk around the trailer again and give each ONE full turn. It works for me!
Ryan
