Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or block...
My routine for TT. Level side to side with wheel blocks. Level front to back with tongue jack, slightly front down. Lower rear stabilizer until touching ground (use plywood pads) Raise tongue jack until level. Done.
