Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or block...
I level side to side with boards under wheels after bump outs are out and then lift front with tongue jack to be half a bubble high for drainage off the back of a/c. Run front jacks down with power drill, not too tight to prevent from lifting off tongue jack. Extend rear jacks with power drill and check doors. If they open, its good. If it drags back off or tighten rear jacks to adjust.
