DtaylorExplorerSep 12, 2013How tight?Having OCD, there are little stupid things that absolutely bug the snot out of me. One of those is how tight to you tighten down your stabilizer jacks after they make contact with the ground (or block...Show More
DE88ROXExplorerSep 14, 2013I run mine down with the drill. I stop when the trailer frame starts to rise.But you will always get some movement as long as the tires are sitting on the ground. Some type of X-chock, either store bought or home made helps take a lot of movement out of the trailer.
Related ContentTight nutsTight turn across narrow culvert?Tight Windy RoadsTight screwsTight sewer hose connections
