jimh406
Jan 13, 2016Explorer III
My reflectix isn't attached to walls. It sits on the window frames and is loosely held in place by the window treatements. If you cut it slightly larger, it is stiff enough to stay in place.
It can be attached with velcro if you want to remove it. I use that on the back window. DW cut it to fit and taped it together inside the cabinet with thin metal like foil tape.
