TurnThePageExplorerJan 30, 2019How to calibrate the speedometer?I'm seriously considering upsizing my tires by about 1" diameter, from 33" to 34". I would like to fix the speedo and shift points to accommodate the new size with as little expense and trouble as po...Show More
BusdriverExplorer IIJan 31, 2019If you only go up 1 inch your speed o will probably be on the money , most factory are off by about 2 mph
Related Content2003 newmar freightliner speedometer stopped workingMultimeter Calibration?Fuel gauge calibrationSpeedometerE450 speedometer issue
