- BurbManExplorer IIIFYI, I spent $$ on the Darco OEM underbelly tape, but the best tape that I have found for underbelly use is the Gorilla Tape they sell at the home centers. Stuff sticks like iron and is impervious to the elements.
- K_and_IExplorerI recently had to do some work that required cutting the coroplast. The dealer had done some taping before I took posession of the camper, and this is what he used:
Tape
It had held up well for 10 years, so I bought the same and used it. I cleaned the coroplast with rubbing alcohol and used a little heat from a heat gun. It sealed up well. - GrandpaKipExplorer IIScrim tape for exterior application. Better than gorilla tape in my experience.
- LwiddisNavigatorPost a review to the tech’s Facebook page. Shoddy workmanship!
- Grit_dogTrailblazerThat makes sense, thank you.
I still believe I’d use Gorilla tape unless there’s an even better reccomendTion come up. - pmlevineExplorerThanks everyone. I have to redo the underbelly tape job done by an RV service tech - I had the black water shut-off valve/&cable replaced, the original underbelly of the TT had to be cut into in order to gain access to replace the valve/cable assembly. After returning home, I inspected the underbelly repair, and found several areas where the tech applied patch tape which did not cover some of the cut seams. I also did not find the patch tape to be of good quality - it’s a long drive for me to haul the TT back to the RV service site, so I’m redoing the patch tape job myself.
Phil - Grit_dogTrailblazerSo seams on plastic.
Most degreasers, like used with water say for engines or floors etc leave a film.
Even some solvents like acetone still leave a film (not detrimental to tape sticking, but not acceptable for a paint prep.
If you use degreasing type cleaners I’d still hit it with a solvent or glass cleaner.
And yes good quality duct tape will last a long time. Especially when not exposed to UV. But Gorilla Tape is the bomb. - Microlite_MikeExplorer IIBest i've found is lacquer thinner or acetone. Other "degreaser" type cleaners work too.
If the underbelly area you are applying new tape has dirt/mud on it, clean first with some spray cleaner like 409, etc. Then wipe with lacquer thinner or acetone. (not mineral spirits/paint thinner as it can leave an oily residue behind).
The more free the surface is free of oily residue, the better the tape's adhesive will stick.
As for Tape, I really like Gorilla Tape in Black for taping my trailer's belly cover where needed. I might even consider Eternabond if I needed something more durable and Eternabond recommends cleaning with their cleaner which is just Acetone in an aerosol can. They also have a primer that really makes their product stick. - Grit_dogTrailblazerNot sure what the tape is doing, what kind of tape it is, or what it is being applied to, but the following applies regardless.
Clean dirt off first.
Then a solvent to remove any oils or contamination if the surface is solvent resistant.
If not, good ole glass cleaner like like Sprayway work well also
44,071 PostsLatest Activity: Sep 17, 2026
