Crumm
Apr 13, 2015Explorer
~DJ~ wrote:
I used to feel your pain!!! It is a real PITA with camper or even towing a trailer using the flat 4. I got the Tekonsha Emulator several years ago. Works good. Has many many miles on it and is covered in grime.
I also wired in an additional flat 4 for the utility trailer as when the emulator is in you can't use the factory flat 4.
Moisture hasn't shorted it out? Maybe I will try the one I have.
On s side note your 2011 should have the option of a permanent disable through the settings while using the admin MyKey.
