c_traveler2
Apr 14, 2015Nomad II
Crumm wrote:
When you put truck in reverse with camper on the reverse buzzer goes nuts as it thinks you are going to back into the camper bumper that is 2' behind the sensors. Hit a couple buttons on the steering wheel and it can be disabled but resets to the on position every time the key is cycled. When a trailer is hooked up the system automatically turns off but not with the camper.
Did some research and one solution was a Tekonsha Emulator which is basicly a test light for the seven way plug which includes a trailer brake control tester. The emulator tricks the truck into thinking there is a trailer connected. I got one in the mail today and while it does the trick there seems to be some vent slots in the bottom of it which I assume is to dissipate the heat created by whatever kind of load cell it uses to simulate trailer brakes. Through these slots I can see multiple electronic components which are going to be exposed to the weather and road spray if the unit is left plugged into the seven way. I imagine it would short out before long.
Back to the drawing board. Any ideas?
Have you tried dis-connecting the wires from the sensors, works on my 2007 F250
