thcguy12's avatar
thcguy12
How to level my camper WITHOUT moving it or using blocks?
SIMILAR POST IN CLASS A BUT THEY QUICKLY INFORMED ME THEIR ANSWERS DON'T APPLY BECAUSE MINE IS A TT. So what do you think???
So our travel trailer is finally on the land however it's really wedged in and there is no way to get a car back in there to move the camper back and forth to put blocks under tires on side that is lower. We had to drive over rocks and scrape the bottom of car getting it out - don't want to do that again.
What other techniques could we use for leveling it side to side (not front to back - that is fine).
We were thinking maybe some stabilizer jacks could help. It doesn't have any front ones now. Thoughts?
Any other ideas since we can't do it correctly with leveling blocks?
  • From who - I asked everyone I know - no one has anything like that.
  • Guess it's time to buy a jack. Dang - was not expecting that expense for a one time use item.
  • Jack up under the axles, then keep the jacks or put blocks under the tires and lower. Then use stabilizers.
  • I would jack it up like I was changing a tire and put some boards under the tires.
  • Jack it up and put something under the wheels. Dirt comes to mind.
  • Jsck it up and put 2x8 under wheels. Other possible way is to jack it up and dig under the high side and set it back down.
  • No matter where you post this question you received excellent advice of how to do it in the class A section.There is no difference other then weight,the principal is the same in leveling.
  • Can you use a bottle jack to raise it, then use blocks?
