dm810910410
Apr 19, 2022Explorer
@Grit Dog, Thank you!
@BigSwick, correct, tiedowns are not installed in the pictures.
@stevenal, thank you for the suggestions. I figured the 2x12’s were overkill and May move to something smaller in the future. As for the potential slip area I did add grip tape to the top of the 2x’s. Been on 5 trips now over some pretty rough roads and haven’t seen any movement. If I do run into a slipping issue I’ll look into adding another mat between the wood and the camper bottom.
Couple more pics of the camper in its element with the tie downs installed.
