Baja_ManExplorerJul 31, 2022How to REMOVE brake drum races using a shop press?Hello all-- I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press. I know there are kits that use machined alum di...Show More
dodge_guyExplorer IIJul 31, 2022A hammer and a drift works great and is easier than setting it up in a press.
Related ContentStaple RemovalEngine accelerates when brake pedal is pressedHamburger PressEasy way to remove slide topper?Removing braking system
