Baja_ManExplorerJul 31, 2022How to REMOVE brake drum races using a shop press?Hello all-- I wanted to see if anyone has a method for removing brake drum/hub bearing races from trailer brake drums using a simple shop press. I know there are kits that use machined alum di...Show More
ksbowmanExplorer IIAug 03, 2022I do like @eHoefler said and quick welding bead and they almost or do fall out when the weld cools and shrinks the race.
Related ContentStaple RemovalEngine accelerates when brake pedal is pressedHamburger PressEasy way to remove slide topper?Removing braking system
