Bank_of_Dad's avatar
Bank_of_Dad
How to remove gutter spouts from TT
I have a 6 year old 23ft Puma Aluminum travel trailer. I live in South Florida so I use it all winter and then cover it for summer and leave it on the storage lot. The cover keeps it clean and minimizes sun damage. Usually an ADCO cover.
But every year, even tho it is padded and no sharp edges, I get holes from the gutter spouts. I have used pool noodles, small light weight plastic balls, tennis balls, bubble wrap and foam on those spouts. Even if the padding stays on all summer, which doesn't always happen, the padded spout eventually wears and tears thru the cover. I am lucky if a cover lasts me two seasons. And yes, I buy the correct size. It is very windy here all summer and fall and the cover shifts no matter how I tie it down.
So now I am thinking of just removing those spouts. They came attached with the trailer, and seem to be attached with just the caulk and putty around the seams.
Has anyone taken their's off, and how did that work?
Thanks.
  • It's usually held by one screw each at both ends and slips in a runner and can be pulled at one end.
  • I have replaced a few of these and almost every one of them had one screw that had to be removed. It was usually located under some caulk or under the plastic edging that covers the awning rail screws. A little prying was necessary to wiggle the gutter spout out from under the metal edging.
