~DJ~ wrote:
fallsrider wrote:
fla-gypsy wrote:
Tire shop while I watch
That's what I did. I also gave the tire rep at the beginning a lecture on making sure the guy in the shop did NOT jack on the axles. I watched, and he used floor jacks on the frame both in front of the front axle, and behind the rear axle, lifting both tires up at once.
What is your procedure for a flat on the road?
I keep a 6 ton bottle jack in the camper, and I have some blocks of wood to set the jack on. I would jack up the frame, with the TT still attached to the TV. I also travel with a torque wrench with the appropriate socket.
