brulaz wrote:
NCMODELA wrote:
One question, how do you know how much you are putting on the tounge with changing the angles, I want to be around 12%. Is taking it to the scales the only way?
I think so.
After filling with gas, I get on the CAT scale 3 times and get Drive, Steer and Trailer weights each time:
1) Fully loaded truck+trailer+WDH,bars normal
2) Fully loaded truck+trailer+WDH,bars slacked
3) Fully loaded truck+WDH, no trailer
Using runs 2 and 3, you can calculate the trailer's GVW and Tongue Weight. Run 1 lets you see what the WDH is doing and whether you are over any of your GAWRs or GVWRs.
CAT scales are cheap for multiple runs. Usually only 1$ or 2$ per extra run. So you can try different WDH settings and see what happens pretty quickly.
EDIT: 1400# bars might be too strong for your trailer. You will be at the limit of their adjustment, and will not be able to fine tune as well.
And what should the numbers look like for a correct hook up? Front axle weight about the same as unhooked?
