jaycocreek wrote:
blckgnx wrote:
Just purchased a 2016 Forest River Rockwood 2304DS and almost froze last night. Temps are 27degree and furnace will not even get close to keeping us warm. Purchased a 1500watt Oil electric heater today, and that will not keep us warm either(we did turn the furnace OFF) after plugging in the electric Oil heater. Please! Any suggestions.
It looks like there are only two heat vents in the whole trailer,one in the living area and one in the bathroom..Not good for cold climates..
I camp way down in single digits or below zero and use a catalytic heater as an addition to the furnace and it's worthless ducts in my trailer..This keeps us toasty warm even below zero..
Infared heaters do a great job in RV's also..They seem to heat better than the standard portable heaters and I have tried them all.They blow alot more hot air than the little ones do.
Good luck in keeping warm and nice trailer!
REAL "infared" heaters do not have a fan, so don't be fooled by those expensive "boxes" where you can't see the infared surfaces, those are not true infared heaters..
This is a "box" that claims to be "infared", it isn't, it HAS a FAN..
THIS IS a real infared heater..
In the second example you will notice the complete lack of fan, the quartz tubes radiate infared energy 360 degrees and the reflective surface behind them helps to focus that energy out the front of the heater.
Real infared heaters do not heat the surrounding air, instead they heat objects like a person.. The huge downside to using ifared is the mere fact that it DOESN'T bend around you.. It ONLY heats the surface that is FACING the heater.. So one side of you is "toasted" to charcoal and the other three sides of you are nothing more than a arctic waste land of freezing..
Yeah, I have "been there, done that".. Many years ago, I worked in a small mom and pop repair shop where they used several different portable heaters to keep the place warm..
One was a oil filled heater and the other was a radiant infared electric heater..
The infared heater only heated the exposed skin and ANY dark object in front of it.. Not fun at all, had to keep moving the heater around the bend to try to stay "warm"..
