mobeewan
Sep 01, 2020Explorer
I was able to pull my 28 ft trailer into my back yard from a private street behind the house tongue 1st by using a front hitch previously had installed on my truck. I left about 6 feet behind the truck before the trailer was in it's final location so that I could unhitch back the truck up and drive around the trailer. I then used a powered tow dolly that I bought to try to get it in its final location but the tires kept spinning on the grass and dirt. The guy that cuts my grass was there so I was able to get him and 2 neighbors to push on the trailer while I guided it into place.
The reason I pulled it in that way was because I wanted the entry door facing the house instead of away from the house since the neighborhood is kind of sketchy. There's only 2 windows on the opposite side of the trailer. One tiny one at the kitchen sink and 1 escape window for the front bedroom which I could block, in case anyone wanted to break the windows to get in.
I'm wanting to move the trailer down the side of the house Because I want to build a shed and workshop with the trailer is sitting. If I pulled the trailer from the back yard to the side yard I then can't get it from the side yard to the street easily Because a crepe Myrtle tree would be severely damaged. So I'm getting a steel fabricator to make some metal wheels with cleats on them that will dig into the turf in order to use the dolly to pull the trailer without the wheels spinning. I found some metal wheels online that are made for using walk behind self propelled mowers on steep hillsides. They are drum shaped with cone shaped cleats on them. However they are $700 the each. I think I can get 2 wheels made that will work for less than $700. I'm waiting on an estimate right now.
Hopefully that will allow me to move the trailer around easier along with putting strips of plywood down under the rear wheels so I don't have a problem with the rolling resistance across the grass. Hopefully this might give you another idea.
I don't think adding a hitch to the rear of the trailer is a good idea since any amount of turning that may occur while moving the trailer is going to put a lot of side to side stress on the rear of the trailer where the hitch would be mounted.
