bpounds
Sep 01, 2020Nomad
RetroAirBnB wrote:
Yes, thank you. That's what I was trying to figure out: how to rig up a tow bar on the rear bumper. There's no products out in the market that i can see which would make that easy.
Depends on what you've got on the rear of the trailer. If you have either a C-channel or square tube bumper back there, Harbor Freight sells an inexpensive tow bar that comes with brackets which bolt right up to a CJ or YJ front bumper, and would easily bolt or weld to your trailer rear bumper. Then 2 pins and it comes right off the trailer for storage.
I think it would work perfectly for you, but you need to make sure your front jack has a swivel wheel, and keep it from digging in to your gravel. The trailer is already front heavy obviously, so it needs to travel and turn on that front jack wheel. You could probably lay some plywood down for it to run on.
Someone above mentioned the door being on the wrong side of his trailer, and that is exactly why my father did this. To get his entry door where he needed it, and the other side was up tight against a fence. He was also fighting a fairly steep incline, but it still worked fine.
