Bedlam
Feb 14, 2016Moderator
Create folders with the album name and copy only those songs to each folder. I only have the uConnect 3.0 and do not have the SD slot - Are you sure the SD slot is not exclusively for radio programming? I have used a USB stick inside the center console and it is protected from being knocked out. You can also use a USB extension cable if the USB connector is in an inconvenient location.
44,066 PostsLatest Activity: May 13, 2026
