Second_Chance
Feb 14, 2016Explorer II
sch911 wrote:
The directory structure should be setup as follows:
Root > Artist Name > Album Name > Songs.mp3
You can have more than one Album folder in an Artist folder.
You can have as many folders / songs as the SD card can hold.
This is the correct answer. Find a good CD-ripping program that will look each CD up in one of the on-line music databases such as Gracenote. I use WinAmp (which is a discontinued product), but I believe Windows Media Player will do the same thing for you. Set up properly, the ripping software will download the metadata, create folders and subfolders as described above, and place all your music in the proper folders with the tagged data. I have thousands of songs and hundreds of "albums" on one USB memory stick. Make sure you rip to a format that your vehicle's sound system can recognize (such as a standard MP3).
The tech corner would probably have been a better place to post this...
Rob
44,066 PostsLatest Activity: May 13, 2026
