kerry4951
Jun 10, 2015Explorer
On an AF front speakers should be wired together, and rears should be wired together. Every time you turn your battery cut off switch on you have to redo the "fade" control. If not the outside speakers (R on the control) will be putting out with the inside speakers (F on the control)). You have to fade out the (R) completely and there should be no sound from the rear speakers. If its not working like that than someone wired your speakers wrong.
44,056 PostsLatest Activity: Jan 12, 2020
