mike-s
May 24, 2017Explorer II
troubledwaters wrote:Antenna up, deliberate action. Open dump valve, deliberate action. Put step down, deliberate action. Water pump on, deliberate action. You've done all those things, so it's up to you to remember.
You going to add alarm for when you accidentally leave the antenna up. Or accidently leave a window open. Or accidentally leave the dump valve open. Or accidentally leave the step down. Or accidentally leave the water pump on. The list is endless. It's a one off thing. Do your due diligence and get on with life. Stuff happens.
Breakaway switch accidentally pulled, you don't know, and there's no indication to make you aware. Is checking the pin on your setup/teardown checklist?
Different things.
44,071 PostsLatest Activity: Aug 16, 2026
