Bobbo
May 25, 2017Explorer III
The only problem with the LED light concept is you have to go look at the light. You could just as easily go and look at the pin in the breakaway brake. There is no advantage to the light. With the buzzer, it will get your attention wherever you are. I like the concept of using a diode and wiring the ground side of the buzzer to the hot side of a brake light. It disables the buzzer when the brake pedal is pressed.
44,071 PostsLatest Activity: Aug 16, 2026
