hawkeye-08
May 26, 2017Nomad
Bobbo wrote:
The only problem with the LED light concept is you have to go look at the light. You could just as easily go and look at the pin in the breakaway brake. There is no advantage to the light. With the buzzer, it will get your attention wherever you are. I like the concept of using a diode and wiring the ground side of the buzzer to the hot side of a brake light. It disables the buzzer when the brake pedal is pressed.
The concept of the light is that you would see it light up when you knocked the pin out. I'm expecting that your pin is not falling out when you are not there??
44,071 PostsLatest Activity: Aug 16, 2026
