69_Avion
May 23, 2013Explorer
Just to make sure there is no confusion, you need an uninterupted 12 volt power supply from the trailer battery to one lead of the break away switch and the other lead of the switch is connected to the trailer brake wire, which is usually blue. You need to check to make sure. If the break away switch is every activated, your trailer brakes should lock up.
44,067 PostsLatest Activity: Jun 05, 2026
