Dtaylor
May 12, 2013Explorer
TecheMan wrote:Dtaylor wrote:Thanks I am extremely good at backing my boat. The key is knowing where your wheels are when starting to back up. They will start making the turn from that point and continue to do so. The tail will swing to follow the wheels. So if you get your wheels where they need to be before backing half the job is won. My biggest concern was will I make wide turn with this long TT and still not beable to get it on my street. Thanks TecheMan I appreciate this I really do. It is so nice to have a place like this where others are willing to help one another with stuff like this.
I tow a 21ft Stratos and a 30ft TT. The main issue I had, and still have sometimes is judging distance when backing so I always use a spotter. Turns, especially sharp turns, you have to watch out more for tail swing on a TT that you do not have with a bass boat. The wheels on a TT are more center mounted than rear mounted like on a boat trailer. Other than the fact that a TT catches more air, I really cannot tell much difference as far as highway towing. I think the biggest issue is your confidence/comfort level. As for the width, from outside to outside, they are about the same. We have some really narrow roads that my butt cheek pinches the seat on when towing both, so that part is the same. I think you are over thinking. It becomes second nature just like it has with your boat
To answer about how wide to swing to get onto your street, You may have to swing slightly wider than you do with your boat. If you are turning from a narrow street onto a narrow street you may have to swing a bit wider. When I am making right turns I will go ahead and take a lane and a half just to be on the safe side even though I may not really need it. Just take the turn slow and watch the track of your wheels in mirror and make corrections as needed.
44,056 PostsLatest Activity: Jan 12, 2020
