ShinerBock
Jan 28, 2019Explorer
VernDiesel wrote:
Yes at 371,500 she pushed out a head gasket likely in part due to having been low on coolant. (more than once as I had been dealing with a coolant leak) This has been covered on this forum several times is not hidden and was not part of the 8 speed transmission discussion. Apparently I should add a signature line with this info in it. :)
Yeah, it probably needs to be mentioned when you state how many miles you have on your truck so people that do not know don't get the wrong impression as they did here. There are many threads that I don't even go into and if someone else would not have stated it in one of the threads that I happen to be in then I would not have known either.
Not knocking your truck, but an engine/trans/rear end/injector/turbo replacement or rebuild is generally stated when talking about that kind of mileage on any vehicle so people don't get mislead into thinking its all original.
