FishOnOne
Feb 03, 2019Nomad
Grit dog wrote:
^ Im sure he means 40psi in the rear tires. And that does not increase tire wear. 40psi in front of a diesel on stock ish size tires is very squishy. Even the most uninformed would notice an issue with that.
60F/40R give or take based on load, road conditions, seasons, tire size and type is the RIGHT ballpark for pressure on unladen HD pickups. This is only debateable if one is obtuse, ignorant or....yup just those 2 reasons.
My TPM light turns on at 50psi so either ignore it or keep your tire pressure above it's threshold.
On my 05 Super Duty I started off running ~50psi in the rears (no TPM)and got around 40k miles. On my third set of the same tires I ran 65 psi and got around 60k miles.
