- Reddog1Explorer IIHow could you be taking advantage if you are honest? You can only tell them what you know and what you think.
- BFL13Explorer IIYes, it would likely go better if I fit swing-outs. I do have some 2by4s to put under it if the buyer has a newer truck with the high box sides and doesn't have any of his own.
Kind of an awkward situation for a sale where most folks don't have a matching truck. (Camper is 11 ft renovated 1981 and is heavy) Can't take advantage of an innocent newbie, but you still want it gone. We'll manage. :) - wanderingbobExplorer IIThe swing out brackets are pretty easy to make , the bolts and steel should cost less than 30 bucks . I think I had to drill twelve holes .
- work2muchExplorerWe also hauled out bigfoot 10.6 on a 1994 Dodge Ram 2500 with airbags as well no issues. At that year the 2500 was built like a one ton. Dana 80 rear axle! We were running around 4k as well.
In general I have never placed limits on buyers vehicles as a term for sale. I simply tell them to do their homework. I am not engineering solutions or offering my unprofessional opinion. - Reddog1Explorer IIDon't tell the weight Police, but I hauled my 4200 lb TC for about 185,000 from 2004 till 2016 on my 1996 Dodge 2500 ext cab 2WD. Air bags with no overloads, sway bar, and 19.5 tires and wheels. Never had a problem.
I would not haul it on stock suspension, and stock tires were borderline. I upgraded to a 2004 Dodge 3500 DRW 4x4 for the creature comforts (softer ride) and wanted a change after 14 years.
Both of the TCs in this photo weigh 4200 lbs.
I would advise a potential buyer they should have a 3500 (not necessarily a dually) or a 2500 with upgraded suspension and tires. When you look close at the 2500 rigs most are way overloaded (per door decal), although few will admit it.
Wayne - work2muchExplorerYou could always buy and install the swing out brackets yourself. The 200 bucks or so might make it easier to find a buyer.
- pianotunaNomad IIIHi BFL13,
Nope they are not all the same width.BFL13 wrote:
Are duallies all the same width no matter what brand or year? Thanks. - BFL13Explorer IIThanks all. My jacks are 90 inches apart and have no swing outs, so that's that.
The camper is 3,000lbs, and I have it for sale. I figure somebody that comes by will have a dually. Now I know what that means. ( I could deliver it after purchase and he could sort out the jacks later at his place on his own time)
My 2003 Chev 2500HD gasser is about 75 inches wide and can just take the weight. Its CWR is 2770 lbs so I steal some front cab weight allowance to make it up to the 3,000. Back tires are right on their max. I am telling folks no 1/2 tons or 3/4 ton Diesels, but without the swing-outs, that leaves no duallies either! Oh well, we'll manage :)
1 inch clearance either side--yipes! Must have nerves of steel. - deserteagle56Explorer IIThis will also depend on the camper and how the front jacks are mounted to it. My Bigfoot had the swing-out jack mounts - but when swung out they still would not allow my Ram dually fenders to pass between them. I had to build extenders out of 4" channel to make them work.
- Reddog1Explorer III can't imagine any would be less than eight feet. Then you have to keep in mind some people install oversize tires and/or wheels, making it wider. Usually the wider tires require wheel spacers making the rear even wider.
Wayne
44,056 PostsLatest Activity: May 04, 2014
