korbe wrote:
Is there enough overlap when the back piece is pulled down to rivet along the joint?
I can't get the metal to move enough to overlap. It will come down some. I'll try to capture a video of what it does when I try to stretch it back to its original position
brirene wrote:
Hmm, if the position of the pieces is not causing any problems, any chance of pop riveting a piece of aluminum up there?
Thats my current plan, aluminum is soft enough I can work it "in place" and then either rivet or using 3m VHB to bond it back together. Then a spray on coat of rubberized undercoating to seal everything up.
beemerphile1 wrote:
Close to my thoughts, I would build a new liner from galvanized steel and put inside the existing.
My fabrication skills are in the microelectronic realm, not sheet metal... so take it to a shop basically?
