DutchmenSport wrote:
Just forget the numbers and the stickers and get an F350 and you will be covered for just about anything you will ever carry in your truck. :)
If 200 or 300 pounds makes that much difference to you, that's too close for margin. Just get a heavier duty truck where a few hundred pounds difference in what you are hauling makes no difference at all.
IMHO that is by far the best advice and safest option. If you keep trying to stuff 10lbs and that 5lb F150 bag all you will end up with is a bulging, overloaded and potentially dangerous ripped bag. Get the bigger and properly sized bag and be done with it.
Larry
