06Fargo wrote:
4x4ord wrote:
I tend to load er up and go. If the truck acts overloaded I take it easy. In Alberta we are supposed to be mindful of our tire ratings.....axle ratings are enforced on big trucks next but disrespecting a vehicles payload, which is derived from the GVWR doesn't have much consequence as far as I know.
4x4ord - yer correct - an AB scale officer confirmed my SRW 3500 on 265mm tires would be legal at 265 x 10kg/mm of x 2 tires = 5300kg per axle OR the maximum load rating/psi of the tires whichever is less. In addition it is an offence to operate a vehicle that is "unsafely loaded." DOT has discretion to weigh any vehicle that appears to be unsafely loaded.
Would this truck be considered "unsafely loaded" as it cruised by a DOT patrol 10 mins before this happened?
That load is about on par with here in the states. 500 lbs per inch width of tire, 265mm is about 10.5" or 5250 per tire, 10,500 per axel. THAT is the legal load I get here in Wa st, as long as I have a paid for license that is at or over this amount. If under this amount, I get the paid for amount.
My C2500 has a paid for plate of 8000 lbs, I do not get to drive legally at 8600 as my door sticker max gvwr per GM states. My old dually had an 11400 door sticker, I have a 14K paid for plate, I was legal to 14K lbs gvwr on the axels. I was good to the 10K ont he front, and 20K on the rear due to tire widths etc. My C2500 is good to 4750 per tire with 245 rubber.
My Navistar is also good to the same weights per DOT ont eh tires as the 3500, as they ea have the same max per axel. Over 30K lbs. I only have a paid for license to 26K, but manufactures rating is 18200. Been pulled over at 27K, did not get a ticket. as I was under the max load per tire widths! All of you will be the same. I was given a 10 day up the registered license to 28K lbs.....I did have to pay for the lack of paid for license. All of maybe $20!
Marty
