dadmomh wrote:
Can you explain to the OP and myself why an F-150 properly equipped is not plenty sufficient?
No, nobody can. The reason that they cannot is because you DON'T NEED that large of a truck for so small of a trailer.
Lots of people here like to cover up poor driving skills or poorly set up tow vehicles by simply throwing money at the problem and buying a heavier truck to mask the symptoms and make them feel better.
A properly equipped truck, be it a half ton or a 1 ton, can safely and effectively tow up to its tow limits. Will a half ton truck hold up over the long term towing at its max weights as a dedicated tow vehicle pulling 12K miles per year? Probably not. The OP isn't trying to do that. The OP is a typical weekend warrior. They are towing less then 300 miles per trip, likely less than 10 times per year. That's 3,000 miles per year towing or less.
For people that have the money or the NEED for a heavier truck, buy a heavier truck. However, for people that don't have the money nor the need than the half ton trucks are great options.
