dadmomh wrote:
dadmomh wrote:
The OP did just purchase the trailer in the last couple of months, so that's a done deal. They spent a lot of time researching in order to make the best decision possible. IIRC, the Sequoia was purchased just about the time the TT purchase happened in order to have something ok to tow with. They are looking to make a change to a PU in order to feel better about the weights, which they are very concerned about at this point. Understand completely. They also want this PU to serve as a daily driver - grocery store pretty much and misc errands. They do not make big trips to Lowe's or HD and load up. They need safety with their new TT, comfort, affordability. Correct me if I'm wrong, but does that about sum it up? Also, they have no plans to do any upgrades to a larger TT, so what they find now should serve them for a long time. IMHO, opinions and suggestions need to be along the guidelines they've expressed. Other "just buy" or "go big" just serves to add to the confusion. They are trying to sort this out step by step.
The OP and DH purchased a Prime Tracer 230FBS....specs shown below. I am having a problem with some insisting that they NEED a 250. Certainly not a weight/towing expert, but after 8 years I have picked up a smidge of info. Can you explain to the OP and myself why an F-150 properly equipped is not plenty sufficient? I believe they are looking for a near new truck, factory tow, doesn't need all the bells and whistles and preferably not, as decent mpg as possible and comfortable. Our '03 happens to meet their needs and I feel sure that Ford built a zillion just like ours over the years. If it all boils down to the tires, that is easily remedied, although it drags up the dreaded tire thread.
Certainly not my intention to be critical of the opinions/suggestions, but the OP has said they are not interested in a 250. Seems like that should be end of that discussion. If not interested in a 250, a 350 is likely not of interest either. What the OP is asking is what to look for in an F-150 that will suit their needs.
The other thing that some are not catching is the age factor/retirement and that when the term "fixed income" hits, the income is the ONLY thing that's fixed. Retirement and the budget is a huge factor, like it or not. DH would "like" a 250, but that's not gonna happen. I would "like" a few things myself that aren't gonna happen. Unless you happen to be part of the AARP crowd who doesn't have to consider budget, I'm happy for you. But the OP has already noted that they do have to consider the financial impact, as we do.
Model 230FBS
Base Weight 4,920 lb. (2,232 kg )
Hitch Weight 635 lb. (288 kg )
Cargo Carrying Capacity 2,677 lb. (1,214 kg )
Exterior Length 25 ft. 2 in. (7.7 m)
Exterior Height 10 ft. 8 in. (3.3 m)
Fresh Water Capacity 48 gal. (182 L)
Black Water Capacity 30 gal. (114 L)
Gray Water Capacity 30 gal. (114 L)
Awning Size 12 ft
Tire Size ST205/75R14/C
I think you have missed the point that the OP HAS weighed their current combination, the payload is already at or above 1,000 lbs.
That "dry" weight is more like 700 lbs empty and when loaded 750-800 lbs..
They also have noted that ALL the F150s they have look on the dealer lots only have a max of 1,200 lbs available cargo weight which is less than 200 lbs more than their current TV..
It is silly to buy a new tow vehicle which will only give them an additional payload of 100 lbs or so above what they have. To really get a much higher payload in a F150 you need to go with a regular cab 4x2 and that is not what the dealers will have on the lots. They will have the loaded to the max models except for HD or Tow Max package..
Bling sells not brawn..
The options are, order a F150 with HD or Max tow package plus the Eco boost V6 (for empty mileage) OR buy a F250 with 6.2..
In the end the price of the F250 is going to be nearly the same or even less than a F150 Max tow and Eco boost..
As others have mentioned A "heavy half" is going to ride a lot harsher then a standard F150..
My suggestion to the OP is to TEST DRIVE BOTH the F150 AND a F250..
Pretty good chance that the F250 will be rather similar ride.. Heck my Dad is 87 yrs young and still drives his 1980 F350 around town and it rides like a buckboard (newer trucks are much smoother ride)..
