brulaz wrote:
Do you truly believe that there is no difference between an F250 and an F350SRW other than "the exception of a slightly larger bump stop"?
Just looking at the 2015 brochure, how do you explain the increased
loadfloor height: a full 2". Clearly the F350 has heavier duty rear springs that give you the increased GVWR and payload.
Perhaps he was slightly oversimplifying... but there is really very little difference between the F250 and F350. The engine, transmission, axles, wheels, brakes, cooling system, steering system, body, frame, etc etc are all IDENTICAL on the F250 and F350. The F350 has an additional overload spring and 2" blocks in the rear.
Someone can go out and bolt on the overload spring or add a supplemental airbag system to an F250 and it will be as good as, or better, than a F350.
His point was that these payload and tow ratings aren't the "SAFETY ISSUE" some on here want it to be. They are numbers agreed upon by engineers who know the fail point, lawyers who know the liability point, accountants who know the cost point and marketing who know the price point. Manufacturers want to decrease liability and warranty repair issues... they have a LOT of reserve built into these trucks. I have every reason to believe these trucks to pull RV's can safely go 10%... 20%... maybe even 50% OVER their rated payload with very minimal chance of causing premature wear. How many miles does the average RVer tow per year? I would estimate less than 5000 miles per year (on average). 50% over your payload for less than 5,000 miles per year and you will likely never over stress anything. On the other hand, if you are a farmer hauling to market or a landscaper hauling around every single day for 15 or 20,000 miles then you are going to have much higher likelihood of wearing out your truck faster.
Its a balancing act. Claim the bigger number than your competitor and keep warranty claims down while increasing vehicle longevity and making the average idiot understand what their truck can do. People can't figure out easy enough concepts like payload, GVWR and GCWR. It would get a LOT fuzzier if you started hearing things like max GVWR when towing less than 5,000 on paved roads vs a lower max GVWR when towing in excess of 12,000 miles on gravel roads vs towing a rounded trailer vs towing a 5th wheel vs this vs that...
My Tundra is rated around 1500 lbs. I don't think its going to fall apart if I load it to 1800 lbs (20% over my payload) and drive a 2000 mile round trip to Florida. It wouldn't be unsafe either, as that extra 300 lbs resting on the truck is countered by 2000 lbs of spare CCC in the trailer that isn't used.
Again... I don't advocate that anyone ever go over their ratings. I just don't buy all the SAFETY propaganda that is thrown around when its convenient to marginalize a group of truck owners because you have a heavier truck.
I do think he is wrong about the GVWR of a F350SRW. Highest I can find is 11,400 lbs.
