jefffoxsrExplorerApr 07, 2014HVAC problem.What is likely the problem when, for example, the driver's hvac zone won't put out heat and the passenger zone puts out heat? Thanks.
rickguExplorerApr 08, 2014I believe the plastic gears in the unit stripped out on mine causing the door to not operate. I could hear the door clunking trying to close.
Related ContentHVAC - No Compressor runAtwood water heater problemHVACTroubleshoot fridge problem...Norcold Model 611 Fridge problem
