timmymacnj's avatar
timmymacnj
Hybrid TT model suggestions?
Greetings all! I am currently pretty far off from purchasing an RV, but after discussing things with the wife, I would like to begin lining things up for it. Our only experience is tent camping, which we have found to enjoy very much, the reason we would like to transition to a travel trailer is to camp in more versatile weather.
Our first step will be purchasing a used vehicle next year. This is the main reason I am looking possibly getting a hybrid instead of traditional TT, not sure if I can find a bigger reliable truck in my budget. Our only tow vehicle right now is a Chevy Trailblazer that I use with our 5x10 utility trailer, so obviously that needs an upgrade. Currently our children are 2 1/2 and 1 1/2, which makes the truck decision difficult. If they were older, I wouldnt have a problem picking out any extended cab truck used, but due to the amount of room their car seats will take up in the foreseeable future, I think I am leaning towards a used expedition/2500 Suburban/Toyota Sequoia. My main issue hear is budget. I will be able to spend around 10 grand on the vehicle, but every forum I have searched seems to be populated by retirees with unlimited budgets ("Well obviously just buy a brand new Duramax or settle for a V10"), which unfortunately just isn't realistic to me. I searched craigslist for some 3/4 ton trucks in my area, and within my budget they seemed very few and far between, with extremely high mileage
Second step: The trailer. I may be able to find a lighter weight TT that suits my needs depending on the vehicle I find, but I am not getting my hopes up. I have seen several hybrids that look like they would meet most/all of our desires and needs, but there seem to be so many I was hoping some people here could narrow it down to some models for me. So far one of my favorites I have seen is the Jayco Jay feather with a hard slide out, is there a specific term for this? Is there a general guide on the hybrids? I have only read about them recently, but they seem to be a good alternative.
Any suggestions are appreciated.
  • Sounds like you've made up your mind :) If you're considering something like the Jayco 23B, a 1/2-ton should be fine, and should fit in your budget. Good luck!
  • kvangil wrote:
    What is the tow rating of your Trailblazer? I know some can tow up to 6500lbs. If that's what you have then it's plenty capable for a decent-sized hybrid (up to 4500-5000lb GW) for a family of 4. We tow a Jayco X23b with Gross weight 4950lbs with a 6000lb-rated tow vehicle and it's adequate. You may not need to break the bank...
    I absolutely want to get away from the trailblazer. I do not want to tow anything more than a 2500 pound loaded trailer in a 6 cylinder. I am currently towing about 3700 pounds with it in a move, and very uncomfortable doing so. That Jayco is one of the hybrids I have been considering, doesn't seem like too much of a trade off. Thanks for the advice.
  • What is the tow rating of your Trailblazer? I know some can tow up to 6500lbs. If that's what you have then it's plenty capable for a decent-sized hybrid (up to 4500-5000lb GW) for a family of 4. We tow a Jayco X23b with Gross weight 4950lbs with a 6000lb-rated tow vehicle and it's adequate. You may not need to break the bank...
  • Didn't read the entire post but at least look at www.trailmanor.com for their foldups and small TT's.
  • Again, if on the fence....don't buy a hybrid....eventually you will want a TT so you won't have to deal with wet bunk ends!! You don't need a 3/4 ton until you get up into heavy TTs. Take your time and look at all the units you can!
    the Jayco you're talking about is NOT a hybrid, since to be a hybrid, it has to have the canvas ends.
    what you are talking about is a regular TT with the bed slideout on the rear, instead of the side, like most other TT's.
    a hybrid TT is a mix of a popup and a TT. body of a TT and canvas bed ends of a popup, hence the term "hybrid".
    most hybrid owners are former popup owners and want more amenities and less setup but still want to "sleep under canvas".
    since you are skipping the popup stage, you really need to decide if sleeping under canvas still, is something you would still love to do.
    if you are on the fence about it, DON'T buy a hybrid.
  • I guess I would be curious to know why you are looking at 3/4 ton (2500 range) vehicles? You state you are looking at lighter weight trailers or a hybrid, but some of these probably would be fine with a 1/2 ton (or smaller) rig.
    I tow my smaller hybrid (Starcraft 18SB) with a Traverse and it does fine. If you want to go bigger in a hybrid or lighter TT, something like a used Tahoe might work.
