mileshuff wrote:
What about a 3 bed pop up tent trailer?  Maybe one that will work for you.
" 3 bed popup tent trailer "   ???????????????????
Having had a couple of popups over the years, and hanging at a popup related forum for a number of years, I can't say I've ever seen one of those?
bikendan wrote:
even the smallest/lightest 3 bunk end hybrid, like the Roo/Shamrock 183, will easily weigh 4200lbs before you put any cargo in it.
The 183 supposedly weighs less than 4000 dry with gas and battery, but as you say good luck finding a good one for $5K and I would go with your 4200 lbs knowing how inaccurate those manufacturer weights can be.
 A comparable floorplan Jayco, the X20D, comes in over 4K dry without gas and battery. Keystone no longer makes a 3 bunk that does not have a slide, both the Bullet and Passport models are over 4500 dry. Dutchmens Kodiak line now has what is called a 179QE cub, a 3 bunk without slide but weights are not listed yet and their sister Aerolite only makes the 224ES which is a much larger 3 bunk with slide, comparable to the Roo 233.
The OP is trying to fill a tall order with their requirements.
