- K_and_IExplorerWith a large Amish population in Holmes County, Ohio, Lehman's Hardware caters to the "non-electric" buyer. They have a selection of gas lights and parts.
Gas Lights - spectaExplorer
jimh425 wrote:
Don’t flush them though. :D
That's some good advise. :B I'll just toss them in the garbage.
LEDs produce a weird light to me. I prefer "softer" light too. - jimh406Explorer IIII’d probably get rid of $1 LED bulbs, too. Probably a good idea before they catch fire. Don’t flush them though. :D
I bought high quality warm white bulbs years ago for the opposite reason of your light. That is, they are zero maintenance and put off no heat. - spectaExplorerNew Humphrey's gas light, $100
6 extra preformed mantels, $62
Extra globe $15
3/8" copper tubing $21
Misc brass fittings $15
Better part of the day installing
Total material cost $213.00
Total satisfaction Priceless
10 LED light bulbs $10 flushed down the toilet. - pasusanExplorer
jaycocreek wrote:
Absolutely... We had both a gravity furnace and a propane light in our '74 Scotty. Miss them every time we camp in the cold. The family would be sitting around the fire telling stories - I would go in the camper and start up the light while I turned all the furniture into beds.time2roll wrote:
JRscooby wrote:
Plenty of apartments use a vented convection heater on the wall and nobody is getting cold knees for it.
Where a gravity furnace could work in a RV, not use electricity it would burn more propane, unless it was below floor level. A wall mounted unit would put heat high in the room, to pool at ceiling. With nothing to circulate it would take a lot of heat to get that pool down to knees. The fan blower reverses the natural flow in the furnace, so the natural flow in the room helps to heat it.
Exactly,we had one in a house when we first bought it..Worked okay just like the gravity furnace did in several truck campers and travel trailers..Those of us that have actually used them in cold temps,actually liked them and the lack of electricity needed...
Those were the good old days... :) - JRscoobyExplorer II
I will not say a gravity furnace will not work. The coal or wood fired gravity furnace was much better than the pot-belly stove, which was better than the fireplace. But as technology evolved, forced air has proven to be more efficient. Maybe a gravity furnace in RV would heat well enough without the need for electricity. But I would be surprised if propane consumption did not increase. Is it easier to carry extra propane instead of extra battery? I can't say. But IMHO, a better idea would be try to make the air handling part of the furnace more efficient. (In homes, the combustion/heat extraction has improved to the point need to use electricity to remove combustion waste gasses, can't use the natural lift of heat to remove. But save enough in fuel to pay for extra electricity.
Gas lights where a great improvement over oil lamps. And in a application where any time you need light you also need heat, and you had ventilation a gas light would likely be the way to go. And like the OP, want for the nostalgia, then it is the right tool for the job. For off-grid living, solar/battery/LED is state of art. But when a local propane supplier will set the tank just to be sure you buy from them, somebody building on a tight budget might install gas lights, to avoid the up-front costs of a solar set-up. As price of solar drops, less likely.
Even more off topic;
In the early '60s the local natural gas company had a "deal". They would install a pole with gaslight where it would light the sidewalk from drive to stoop. About 1 in 4 houses on the block had them. How much gas did they sell with all those lamps burning 24/7/365? - Grit_dogNavigatorWish there was a lime button. Well put spectra.
- Edd505ExplorerWhen you live off grid you use propane lighting, here a few of many.
- jaycocreekExplorer II
Exactly,we had one in a house when we first bought it..Worked okay just like the gravity furnace did in several truck campers and travel trailers..Those of us that have actually used them in cold temps,actually liked them and the lack of electricity needed... JRscooby wrote:
44,027 PostsLatest Activity: Mar 05, 2025
