Huntindog
Aug 13, 2014Explorer
CKNSLS wrote:Proper parameters...The Weekenders wrote:Huntindog wrote:
Here is a observation of mine..
This forum seems to have a lot of folks with marginal equipment for towing.
Not to demean anyones choices and/circumstances, but think about how many posts we have from those with barely adequate TVs.. Those that never carry any water in order to make weight. Those who can't see getting a properly sized TV for the job, when they will only tow a few times a year.. So a nice daily driver is more important.. Or someone that won't consider a tire that can be safely operated at speeds above 65MPH..
I would suggest that some of these people are unsafe at speeds lower than 50-60 MPH... But then again maybe a lot of them are the ones dissing the higher speed drivers because their setups are so marginal, that they cannot imagine anyone having a better one... How often we hear from someone that finally got a dually... And now understands.. Often one doesn't know what one doesn't know.
Food for thought.
Well said!!
Don't know why if you tow at safe speeds (and are not towing a heavy fifth wheel) why one needs to consider an LT tire. There are a few quality ST tires out there that will hold up driven under the proper parameters.
Ok here ya go.
65 MPH is the MAX for an ST tire... Period. Every time you exceed 65, you are damaging the tire. This damage is cumulative. In other words, a failure won't happen immeadiatly. But it will at some point as the damage is hidden and adds up over time.
So you cannot exceed 65 when passing.. Period.
You cannot exceed 65 when going downhill.. Period.
You cannot exceed 65 when merging on the freeway.. Period.
Your TT transport driver cannot exceed 65 while delivering it to the dealer.. Period
You cannot exceed 65.... Ever.. Period.
If you are OK with those parameters... Go for it.
But those are YOUR parameters not mine. I expect more out of my equipment. I paid the money for it, and it is legal, so MY parameters are higher than yours... And I'm OK with that. :B
44,071 PostsLatest Activity: Aug 16, 2026
